hi every one, need help with a volvo ec240lc with i believe a d7e engine, was running fine everyday grapple log loading and started billowing out white smoke no power , code for number 5 injector showing so have replaced all 6 injectors at moon beam price ,$690 each!!!!! drained the fuel, replaced both filters cleaned tank, changed tank to primary filter fuel line.. so the bosses face after spending all that money and down time he wasnt a happy bunny when it started and smoked with no power under load,
a new code showed ma2504-05 which turns out to be a coil solenoid on the head for oil pressure to v/ timing i believe. so tested resistance form ecu and all in spec voltage fine but slighty high ohms across coil, so replaced coil and low and behold still BL@#dy smokes with no fault codes showing ,
no blow by breather / filler cap any things to check i.e EGR before pulling injectors again out to do compession test,
thanks for reading simon
