Hello everyone.
I bought a used Volvo EC210LC excavator, from 2000, which has some problems. !! :-(
Maybe you can help.
1. Right belt motor does not respond when stepping on the pedal. However, if you swing / bend slightly with the left joystick, it will pull well with about 25% force. !!!
2. In the right joystick, the piston for the bucket does not work, and it only has power when it is to lift the entire arm. and no force when pushing the arm into the ground / or lifting the machine, for example.
As I see it, the right belt, the piston to the bucket and the two lifting pistons, all on pump 2, are closest to the engine. so maybe the pump controller doesn't work for pump 2. But then I just think it's strange that it seems to have full power when it has to lift the whole arm. !!
But if pump # 1 can somehow deliver oil to lift the pistons, it makes sense why it can lift the whole arm !
Maybe you can help.
