Tudur DAvies
Hi,
Recently had a fuel pipe leak (part no VOE20838200) on a Volvo EC210C which caused the engine to stop and show error code SID232-04. Replaced pipe and engine is still sometimes throwing error code SID232-04 and will stop itself. The pipe was a double headed pipe which I believe feeds fuel into the two high pressure pumps.
When it doesn't show the error code, machine is underpowered, when in service menu, engine load will not go over 50%. Would that be the machine staying in limp mode? Common rail pressure readings on the screen seem ok, 300 to 400 bar at idle and around 700 bar at working RPM.
Low pressure fuel system stays constantly at 7bar when machine is running.
Should the low pressure system fluctuate slightly or is it normal for it to stay fixed at 7 bar?
