Volvo EC160D?
jca57jd
NC
Hey guys! Looking at buying me a 15 or 16 ton class machine. Was looking for a cat 315c with under 4000 hours but that’s been near impossible to find. The Volvo excavators seem to be good machines and keep a lot of people happy. I know the EC160C is a solid proven machine but I havnt heard much about the pros and cons of the d series. I own a small clearing and grading company and I’m wanting to add a excavator to my fleet to accompany my cat 953b on clearing and grading jobs. It’s hard for me to find a Volvo c series with low hours as well. Found a 2013 EC160D that has 2400 hours on it and it seems to be in pretty good shape but I know it has the dpf and regeneration system on it. This same seller also has a 2015 ec140e with 2100 hours for nearly the same price.
- Are these models know to have any specific problems?
- is this a good reliable machine that I can do basic repairs on in house and work on?
Thanks!
funwithfuel
Will county Illinois
Mechanic
Aside from regen problems, they are as solid as ever. Smooth , efficient and comfortable.
That has the little Deutz engine. Very reliable. The burner and temp sensors for regen are the biggest issue.
I know you mentioned not being able to find a "C" . That is what I would look for if given the time. The C & D are almost identical hydraulically, the difference is one has regen. Other than that, same animal.
Good luck in your search and selection.
jca57jd
NC
Thanks for the knowledge funwithfuel! Are you a Volvo mechanic? After doing some research I found out about a company called AKZO that offers a regen by pass module that makes the computer think it’s there and working but actually deletes it. What are your thoughts on this?
funwithfuel
Mechanic
You dont need that, it will cost you a fortune in the long run. The Gov't is reaching further and further day by day. You are too far away from Canada or Mexico to try n use that stuff.
