need some help. My excavator is running hot. The needle gauge says its fine, but the temp sensor and buzzer come on after a few minutes.
I put a heat gun on the motor and it was reading 215-225 degrees. I replaced water pump, thermostat, and radiator cap. Pulled radiator and not much crap in the fins but a lot were damaged. Spent hours straitening what i could and it still is running hot according to the sensor. Is it the radiator, combination of crap internally and some of the damaged fins or is there anything else i can look into? Thanks for any help!
