Volvo DEF issue
DB2
Winnipeg MB Canada
5AE6FD04-E638-4945-A180-2C944AD51EAE.jpeg We have a 2015 G946C which has started displaying the above warning. We have replaced the fluid and the Volvo tech is telling me the sending unit in the DEF tank is faulty and must be replaced. Anybody have a work around? Do these things corrode given the nature of the fluid they are immersed in?
Any insight would be appreciated.
Seasons greetings to all !
BigWrench55
Somewhere
Common failure with Volvo. If you only drained the def and refilled it with the key off. Then it didn't reset the timer. If the sensor hasn't failed then the only way to clear that fault is to have software. Or drain the def and before refilling. Key on engine off and refill. The computer will see that as a refilling event and run a quality check.
DB2
Winnipeg MB Canada
Thank you. I’ll definitely try that.
Should key on engine off be followed any time we’re refilling ?
We just spent $5K plus replacing the DEF pump itself. Frustrating to say the least.
cuttin edge
NB Canada
Finish grader operator
We had issues with our L180H. Volvo does most of our work. He said that you need good quality DEF. Meaning, don't be refilling jugs out of barrels, unless you can keep it clean clean clean. They have been pretty careful, and so far so good. Been a year without any issues.
A service manual won't necessarily tell you how to solve DEF issues, especially if you've been following the recommendations from the manufacturer.
DemiGod
Wyoming
I have a L-90H that I deleted the dpf unfortunately my programmer didn’t delete the side that is reading the def level. So I derate because of low fluid level. Does anyone know where that sensor is located?
cuttin edge
NB Canada
Do you still have the tank? Ours is filled with washer fluid, just so it won't freeze.
