Have you serviced the return filter in the brake oil tank? Does it have oil in it, it is separate from the hydraulic. After you have verified, that you have sufficient oil, please see attached. Some of the images were cropped in the text, I posted them separately. Make note of the pressure reducing valve to maintain your correct cut-in / cut-out pressure. I wouldn't pull the trigger on the pump, until you have ran down all other variables.
