Volvo A25D
Discussion in 'Other Earthmoving Equipment' started by ms0115, Oct 7, 2019.
  1. ms0115
    ms0115 Well-Known Member
    Mar 3, 2014
    194
    Ethridge, TN
    2005 Volvo A25D
    Serial # - A25DV13985
    Where is the best place to have the transmission rebuild for this A25D? I have pieces of clutch in the pan.
  2. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    2,190
    Mechanic
    Will county Illinois
    There is a place outside of normal channels that offers a great exchange program or they can rebuild yours. PM me if you're interested. I don't want to cross a line .
  3. sfrs4
    sfrs4 Well-Known Member
    Jul 22, 2013
    119
    parts admin
    Great Britian
    We'd offer, but wrong side of the pond for you, i'm sure FunwithFuel will be able to sort you out though.
  4. ms0115
    Mar 3, 2014
    194
    Ethridge, TN
    Any pointers on the transmission removal? It is in the shop, bellypan is off, fluids are drained. And the fun will begin in the morning. Thanks.
  5. funwithfuel
    Mar 7, 2017
    2,190
    Mechanic
    Pull the interior, seat and floor covering. Remove the floor pans. Run a crane job through the door opening. Use lift eyes or clevis to secure to 4 lift points. Tie drop box back toward articulation joint. Remove prop shaft. Remove filter head from RS. Lower trans down and out . Note that you will have to go near vertical with trans to go down, some guys have been successful pulling up through the cab and out the door with both knuckle boom and tele boom cranes.
    Good luck.
  6. Pocho86
    Pocho86 Member
    May 6, 2014
    16
    Heavy Equipment Mechanic Owner Operator
    Kihei
    Its an Allison trans. Contact these guys below and see if they can help. They been able to get me torque converters for JD and Volvo Art Dumps before.
    Need to get info off the tag on the RH side of trans were the trans connector is at. There is an allison tag. its most likely a 4500
    https://www.xcallibertransmission.com/renewed-allison-transmissions/
  7. ms0115
    Mar 3, 2014
    194
    Ethridge, TN
    Thanks for the information guys, got it out today. Not the easiest transmission to pull.
  8. sfrs4
    Jul 22, 2013
    119
    parts admin
    Great Britian
    Not sure where your information is from but as far as I've always known, the Volvo PT range transmissions are in house, the last time an Allison trans was used was in the old 5350B's after that it's ZF until the D's when it went in house Volvo, until the A60H which is back full circle to Allison!
  9. Pocho86
    Pocho86 Member
    May 6, 2014
    16
    Kihei
    Well sorry, I was actually assuming based on the style and look of it, not actual facts. I know alot of them all just use Allison cause they are reliable, strong, small, easy to adapt too, easy to get parts and also rebuild.
    sfrs4 likes this.
