- Joined
- Jan 21, 2007
- Messages
- 13,373
- Location
- Alabama
- Occupation
- Running what I brung and taking what I win
TCO market to the local commercial electricians or whoever pours light pole bases in your market. How it works here is the electrician either subs it out to the one guy with an auger truck to put them in and he handles all of it or they dig the hole, set the rebar, ground ring, conduit and sono tube. Then after inspection, they pour it.
It always seems to be a three ring circus between getting them ready, inspection and pouring. If there are 3-5 light pole bases on a typical McDonalds or other retail site, a 7 CY load is more than enough depending on the base spec. Just a thought.
Another contractor to target is utility guys. We install underground fire mains and hydrants from time to time, there is always a kicker or two or more depending on the project. If there are one or two kickers on a small job we'll mix and pour from bags. If there are more or we have a couple of large ones we call the redimix plant. I'm paying around $450 for a minimum load because we are not a regular client. However it saves labor and time which equal dollars. There is a point where it's too expensive to mix it by hand.
If I need 1.5 CY and can get it on the job for $100 less than a plant mix short load, I am on it like a dog on a bone.
