vibromax steering
Discussion in 'Rollers' started by kgwfarm, Feb 16, 2019.
  1. kgwfarm
    kgwfarm Member
    Jan 16, 2016
    12
    georgia
    During cylinder test return line from cylinders to hmu had oil flow. Beleived internal failure of hmu. Both steering cylinders packing checked good, and steering system pressure checked good. Customer wanted to try hmu as probable cause and get machine to job site.
  2. TVA
    TVA Senior Member
    May 14, 2018
    1,106
    USA
    No, what was the initial problem?
    Why you started testing cylinders?
  3. kgwfarm
    kgwfarm Member
    Jan 16, 2016
    12
    georgia
    Steering wheel was requiring excessive force to rotate.
  4. kgwfarm
    kgwfarm Member
    Jan 16, 2016
    12
    georgia
    Wanted to eliminate a blown or leaking packing first.
  5. TVA
    TVA Senior Member
    May 14, 2018
    1,106
    USA
    Got it.
    So as far I understand with the new one it’s all the same?
    Want to make sure that you understand correctly - flow out of hose normal only at steering neutral!
    Actually if in that system if you pushing oil to the head side of the cylinder, your rod end hose is open to the return gallery of the steering system which is also a charge gallery of hydrostatics ( unless I missed a check valve in the diagram). So having flow on that hose is normal when trying to operate the steering. Plus it tees in to the head side of the another cylinder which can be leaking.
  6. kgwfarm
    kgwfarm Member
    Jan 16, 2016
    12
    georgia
    Flow i was seeing at cylinder stall and continous rotation of wheel to pressurize cylinder barrels and check leakage of seals. Return line disconnected so oil would show if seals blown. I use this test often on cylinders and don't get flow from return line that is disconnected. Sorry for long explanation just want to make sure we are discussing the same thing.
  7. TVA
    TVA Senior Member
    May 14, 2018
    1,106
    USA
    I got you!
    To test cylinders that way on this system you would have to disconnect steering from drive.
    Did you test both cylinders this way, or just one and then saw this flow and moved on to orbitrol? Because the other one might be leaking if you didn’t test it.
  8. kgwfarm
    kgwfarm Member
    Jan 16, 2016
    12
    georgia
    Tested both and witnessed flow described both times.
