rditz
Thank you in advance for any opinions or advice that helps us getting this machine to turn as it should...
boss bought a vermeer flextrack 75 from auction a couple of years ago.. it is a vibrating plow for installing cable, conduit, etc... this things runs good, but it has a couple of problems that we need to fix... first, it doesn't want to turn. it would turn to the right when it was cold, but after three hours of plowing it wouldn't turn at all. it is a track machine but has a steering wheel.. if turned all the way to either the left or right the machine either stops moving or it starts to go backwards slowly.. it is also hydrostatic drive (or some form of it..) second issue is track speed, there is a switch on the dash for high or low track speed, but it doesn't make any difference.
thoughts/advice would be greatly appreciated..
rod
rod
