Valve Lash Specs John Deere 4039df
David369
Can anyone tell me what the spec measurements are for doing the Valve Lash on this engine. Thanks for any help you can give.
MarshallPowerGen
NW USA
David369
Hi MarshallPowerGen, thanks for the information. I downloaded the manual and everything I need is there. Thankyou, this is very much appreciated.
Diesel Dave
Ontario Canada
How much space is there between the top of a piston and the valves at TDC on a 1995 John Deere 4039t?
Deere does not list the thickness of the cylinder head gasket at all so an accurate answer to your question is difficult.
If the following dimensions (shown in the 3 screenshots below) are all in spec, there should be no issues with valve to piston clearance.
Specs below from Deere manual CTM8.
