petepilot
I want to put together a 3 filter used oil filter setup. one filter on the pickup side & two on output not looking for high gpm 5-6 gph would do` oil is a mix motor gear& hyd & likely a little water. need a recomendation for type of pump to use will be elec powered 110. v 3/4-1 hp motor
