Tubine 46 vs AW 46 question
Discussion in 'Lubrication' started by Ric Stewart, May 28, 2018.
  1. Ric Stewart
    Ric Stewart Member
    May 14, 2018
    10
    Seattle
    Was looking for some aw46 on sale which I usually run in all my machines and found some Turbine 46 for cheap.
    Will this stuff run ok in older equipment instead of aw46 ? Better or worse?
    What is the main difference's
    Thanks
  2. kshansen
    kshansen Senior Member
    Mar 11, 2012
    7,268
    Central New York, USA
    My thoughts would be if you know who made the "turbine 46" would be to contact the manufacture and see if they will give you any information.
  3. repowerguy
    repowerguy Senior Member
    Mar 19, 2015
    654
    mixer truck mechanic
    United States southern Ohio
    When I worked at a chemical plant a few years ago, they ran T 68 in centrifugal pumps for lube oil. I think it has very low foaming quality to it. Obviously the 68 is a little more viscous than the 46.
    If it’s not a critical hyd system it should be ok.
  4. Ric Stewart
    Ric Stewart Member
    May 14, 2018
    10
    Seattle
    Another question, The Turbine oil is gone but I did find a barrel of AW32 for cheap
    and also a barrel of DTE 46. I know the AW32 is a little thinner and understand
    the basics of it but am curious if the DTE 46 could be used instead of AW46.
    Anybody done this yet?
  5. blitz138
    blitz138 Senior Member
    Jun 23, 2011
    327
    Utah
    Don't run turbine oil, it lacks AW.
    Why are you looking for cheap stuff? Cheap/ wrong/ dirty oil will create 100 x the problems than the pennies you saved.
  6. Ric Stewart
    Ric Stewart Member
    May 14, 2018
    10
    Seattle
    Was only ASKING about the turbine oil as an option but it was sold. They also had some Mobile DTE 25 ISO 46 oil and am researching its property's. Mobile oil did get back to me and said I could mix the DTE 25 into my AW46 but the DTE was a much better oil. Since I can purchase the DTE 25 Premium oil for a great price sounds like a deal to me.
    Not looking for "cheap" oil, just a good deal.............
  7. blitz138
    Jun 23, 2011
    327
    Utah
    No offense meant. I'm a lube nerd.... DTE is a high end hydraulic oil.
    Ric Stewart likes this.
  8. kshansen
    Mar 11, 2012
    7,268
    DTE 25 last I knew was the hyd. oil they were using on 90% of the equipment at the quarry.
  9. Ric Stewart
    Ric Stewart Member
    May 14, 2018
    10
    Seattle
    Mobil's web site did mention some big quarry's and a great review on matinence savings.
    Unfortunately I am getting an education in the fine print and numbers. The DTE oil is actually DTE26 and ISO 68 weight. Its a great deal and I am told that older machines don't mind the thicker oil
    but new machines require the 46. Since I have "older" machines I might pick up a few barrels.
    Thanks for the input.
