Trucks carrying dirt onto highway
5.9rookie
Caddo Mills, Texas
I’ve got a select fill pit, that I’m having trouble with trucks carrying dirt, sand out on road. My haul road has been topped with asphalt millings. In dry weather, the water truck keeps the dust down and keeps most sand from leaving property. I have a cattle guard also at the gate. In the winter is when I have this problem with the tracking. I’ve seen these shaker plates on the internet for job site exits. They look like I-beams with angle iron welded to them. Anyone have any experience with these? I own the property so thinking about setting up something permanently. We went from loading 50 trucks a day to 100–150 a day. I also think they would make good speed bumps to slow a few of the idiots down. Any ideas or suggestions would be appreciated.
Ronsii
Western Washington
s/e Heavy equipment operator
A drivethrough wheelwash is not an option? or you want to keep it as cheap as possible?
I have also seen some of the yellow composite things they put on sites closer in to town like this one. And I believe you just flood it with a water wagon or firehose to clean into the side ponds.
and then there are the regular types.
Bls repair
S E Pa
Equipment operator,mechanic
Around here if it is to big a problem you have to make a big stone pad and break out the pressure washers for every vehicle leaving the job:D
5.9rookie
Caddo Mills, Texas
Ronsii, i like that second picture. im thinking about setting up 2 or 3 sets of those up on haul road. That first pic looks interesting, but looks hard to build. Im also going to rig my water truck, where i can pressurize my gravity drip bar with some nozzles. Im hoping with the nozzles i can spray the dirt off road. May even hose off the highway that way. Bls, I hope it never gets to that point around here.
HardRockNM
New Mexico
Miner
Those "yellow composite things" (I don't know the proper name either) work quite well. We've got one at the exit of an asphalt/concrete recycle yard and tracking out of these is minimal.
Ronsii
Western Washington
Same with most of the cities around here, they'll red tag your job if you start leaving tracks.. and don't have friends in the right places ;) Some areas are better than others if they see you sweeping and are not leaving clumps of mud and stuff like that they are pretty nice about it.. they understand it's hard to get wheels completely clean without a lot of extra costs especially with smaller jobs... then again if you get a by-the-book-greenie inspector.... you're screwed :(
RZucker
Wherever I end up
Mechanic/welder
I worked on a job in Lacey back in 1998 as a maintenance contractor. (my truck, not theirs) one day on a Friday afternoon a Jeep Cherokee comes blazing/splashing through the TIRE WASH PIT, a woman gets out and starts Screaming at me about mud stripes on the road (we had ONE entrance with no mud on the road) the more I tried to explain I had nothing to do with things, the madder and louder she got. I finally told her that if she was a man I would beat her into the ground. She shut right the heck up, and let me call the GC I was working for.
Turned out it was some carpenters on the far side of the site that jumped the curb and left a few tracks. Turned out that she was the top dog in the Thurston co. "air quality" office. What a (unmentionable) person that was.
Ronsii
Western Washington
Yep, ran into her type before :rolleyes: worst thing is they ALL believe they have the power of GOD to do whatever they THINK is right.... and there ain't much you can do about it usually :mad: so they go all over the place costing guys lots of money because didn't you know!!! that tire track of mud will kill thousands of cute little baby salmon :eek: when it hits the river!!!
The didn't you know has been replaced with {what were thinking, when you got up this morning didn't you know?} My reply to those remarks would sound something like this.
No I didn't know and wasn't thinking about mundane crap like that, you see I was busy squinting trying to turn on the coffee pot with my right hand and scratching my a$$ with the left hand.;)
Ronsii
Western Washington
Around here they usually put a bed of 1 1/2" crushed stone at the entrance, works the same as the yellow composite thing
The requirements for regular construction entrances in this area are a foot thick of quarry spalls 4-8 inch some of the neighboring areas allow slightly smaller quarry rock and when the project wraps up you have to remove it... so usually we put it in deep so it has room to cover with a few inches of crushed to finish grade :)
Oh, and length has to be enough that a full sized truck tire gets something like three full revolutions... or something like that basically they want it 25-30feet long... oh also 12 feet wide with a widened 6foot radius on the sides.
Toronto
I wonder how effective those yellow things are, do they actually remove enough dirt from the trucks for them to safely drive on highways?
5.9rookie
Caddo Mills, Texas
I had rumble strip thing made. It’s 13’4” wide by 25’ long. Made out of 6” H beam with 2” angle iron every 6 inches. That gives 2.5 revolutions on 11r24.5 tire. This thing was worth the money. Really cleans tires up. Not completely but way better than without. I’m planing on putting one more on the haul road. I recommend this to anyone having same problem.
Ronsii
Western Washington
Cool!!! did you put it at a slant so the dirt leavings can be washed away or is this just something you'll lift and maintain when it fills up?
Got pics :)
5.9rookie
Caddo Mills, Texas
For now we will just pick it up and use loader to move the dirt. I’m trying to figure out how to set it up to wash it out. With 5 H beams , I can’t figure out how to wash the dirt trapped between them. I may be able to blow them out with air but haven’t tried yet. I’ll try and get some pics.
5.9rookie
Caddo Mills, Texas
Had a guy tell me on those yellow composite things, they will roll tires off the wheel on like lowboy trailer. He works at a city run mulching operation. They have unlimited funding. He said wheel washing station worked best but was problematic
Mother Deuce
New England
I had a brief meeting with the director of the Bellevue Street Dept about 1978, regarding dirt on his street. He was a very unhappy camper. After he had exhausted his verbosity arsenal on me and threatened to close down the project. I like RZ had to direct him to someone that was empowered to deal with his belief that "his street" was a work of art somewhere on par with the Sistine Chapel.
Ronsii
Western Washington
I'm glad we never ran into that guy :eek: We've done a lot of work in bellevue for the parks dept. I can remember several times on jobs the boss saying 'we could never do this on a regular job up here!!!' but since we were on a 'parks dept.' job it was kinda like anything goes ;)
