ColdBlackWind
While changing tracks on the machine I developed a catastrophic leak in the hyd system. We were bumping the left drive to aid in getting new track over front idler pulley. I heard a pop and the hyd oil flooded out from underneath the machine. After raising the cab and removing sheet metal to expose pump, foot valves and hoses I have yet to find the source of the leak. I was going to put a couple of gallons of oil in the system and bump the motor over with a remote start button but I am not sure about how the park brake and permissives work. Under normal conditions after starting all controls are locked out until park brake is released. Is that a bypass in the pump? No controls were being operated when it emptied the system. What would be under constant pressure with everything in “neutral” to allow it to pump out all the hyd oil?
