Good to hear (kind of) JR. Too bad the pump is on its way out, but maybe you can find something in the mean time while you can still run the machine.
I'll just reiterate my symptoms-
- Lack of power when tracking / pushing material
- No difference when high speed is selected while traversing an incline
- Negligible difference when high speed is selected on flat ground
- Lack of power in left track compared to right track (this was not as apparent in my machine compared to JR's by the sounds of it, as the machine did not have a noticeable drift when traveling so i did not choose to bring it up, however it was apparent)
- Boom alone will not raise/pitch machine without help from other functions
*Ive verified and resealed system reliefs.
*Ive verified case drain of each travel motor
*Ive verified condition of swivel joint
*Ive verified pilot pressure
*Ive verified mechanical operation of travel valve linkages
*Ive verified operation of high speed travel (both electrically and hydraulically)
*Ive verified there is no restriction in return flow to tank
*Ive verified, as well as possible without removing valve bank for further inspection, the condition and operation of the main cut off control valve
Uffex's point of reduction in flow in one side of the pump verses the other made good sense. Since I also had a somewhat lazy track, swapping lines seemed like an easy way to test as the fault should move to the other track. Swapping lines showed a transfer of the lazy track from the left to the right side, which to me, narrows the issue down to the pump. I will not say this is definitive yet, and plan to drop by a friends place to flow test each side of the pump.
Assuming each pump in either machine is worn, i am of the opinion that JR's pump has more significant wear on one side of the rotary group versus the other, while the wear is more even across both rotary groups, however still slightly more pronounced on one side, in my machine.
I believe it would make sense that we do not see a reduction in system pressure due to the "horsepower control" capability of the pump, up to a point. Referencing the chart I've attached, the maximum force "F2" has remained constant due to the system reliefs, maintaining the capable pressure. Load "F1" has, in 3 of four scenarios, never changed, and the pump is still capable of suppling system pressure. However due to wear either in the pistons, barrel, valve plate or a fatigue in the spring, it supplies this pressure at a reduced flow rate, which is most noticeable while tracking, especially in high speed.
So I did what i was apprehensive to do from the get go, I turned swash plate adjustment screw in, by 1/4 turn increments to a max of 3/4 from original setting, and monitored system relief pressure, where there was no change. This may be an indication that the spring did not fatigue. The pump now takes in more fluid by volume, making up for the bypass. The machine now tracks at an acceptable speed and has no issues pushing material.
I'm not considering this a fix until i flow test the pump. If it checks out, ill boil it down to the spring fatiguing over time and in that case, i'm not too worried about it. If the flow test shows a poor result, Ill begin a search for a pump or a rebuild kit if available (price dependant). In the mean time, I've some jobs to do, so if it pumps, it digs.
Im simply stating my thoughts here. If you see any flaw in my logic please point it out and correct me. Id rather be just dumb, not dumb and ignorant.
