mayn4u
I tried posting this question earlier and didn't know what I was doing so I'll try again.
I have an older TB42 Snorkel lift and it won't switch to hi-idle unless I manually pull the solenoid back with the switch engaged.
I've tested the relay out and it seems to be sending the signal. This also happens when I try to operate the choke. The throttle solenoid has 3 wires and
the choke has 2. I did pick up an answer from some out there but lost the reply so I'm trying again.
Thanks, Mayn4u
Thanks, Mayn4u
