HandLogger
Having problems starting an '88 TD-8E. This machine was running fine a couple of days ago, but now it "clicks" when the starter button is pushed.
Specifically, I'm hearing nothing but a click sound coming from what appears to be a "starter relay" mounted on the left side of the engine: ABOVE the starter/solenoid. To clarify further, the starter relay I'm referring to is not part of the starter/solenoid, which is located about 8" below the unit I'm referring to.
I'm no dozer repair expert, by any means, so my reference to the phrase "starter relay" is only a guess. The part I'm referring to is wired directly to the alternator on one side and has various wires connected to it (from other locations). This part is round (about 2" in diameter), about 2.5" long and is painted yellow.
I'm in a real jamb here, so I would appreciate any productive feedback or suggestions.
Thanks for your time,
HandLogger
HandLogger
