chansey
This thread will document what needed to be accomplished to repower a 1989 Trojan 1500Z with a rebuilt Cummins 4BT with 130 HP. The engine repower will net a additional 37 HP over the Deutz F5L912.
The original Deutz is a rebuilt engine (2006) that had a rod knock when I purchased the loader. Took the engine out and the crank was ground for -.20 rods and -.10 mains, new rings, bearings and new rod/piston.
Had a Cummins Reviva 4BT and a rotary pumped 6BT sitting in the garage. The 4BT was scheduled for installation in my 1942 G506 (1.5 ton Chevy) however I will be using the loader extensively and decided to install the 4BT in the Trojan 1500Z.
As with any repower, it’s never a straight drop in and bolt up situation. New metal fab and parts are always part of the process. To start with, need to see what is at hand and where we need to go.
The 4BT is equipped with a SAE #2 flywheel and flywheel housing and a 10 spline 14” clutch. The Deutz F5L912 has an SAE #3 flywheel housing. The transmission is an Allison TT222-1 transmission with an SAE #3 bolt pattern. The Allison flexplate consists of 3 separate plates that are center mounted to the transmission torque converter and the 8 outer bolts mount to the flywheel. The 4BT starter is retained.
The first task is to mate an SAE #2 4BT housing to an SAE #3 transmission. C and C Truck Parts offers an SAE #2 to SAE #3 adapter ring for $75.00. Others want as much as $550. The Deutz flywheel is flat and the SAE #2 Cummins flywheel has a recess for the 14” clutch. Sent the flywheel to the machine shop to mill off the ridges for the clutch and provide an index for the flexplates.
With the mating and coupling issue solved, here are some of the known items that need to be addressed as the project moves along.
Fab new motor mounts for the front and rear of the 4BT
Fab mounting bracket for the transmission oil cooler
Add Cummins gear driven air compressor for brakes
Fab, find install radiator and coolant lines to engine and air compressor.
Fab brackets/mounting for radiator
Add air to air cooler
Deal with other details for electrical, throttle, engine shutoff, etc
Paul
Paul
