When you get your book it'll have part #'s in it. When you figure out what you need, call Minnpar on the phone, the guy there helped me out fine. I needed some seals to stop a few oil leaks on mine, steering motor, dropbox, etc. A few he had on the shelf, a few he "spec-ed out" and found them somewhere. Very reasonable prices too. My brakes worked, just the master cylinder leaked all over the floor of the cab. If you read that thread, it'll tell where I got a kit & fixed it. Theres probably a reason the guy cut those lines on yours, like blown out wheel cylinders, etc. Once you get the book, it's easier to see what goes where. Up under the floor is a hydrovac that has to be bled too, two fittings on it.
