old-iron-habit
- Joined
- Nov 22, 2012
- Messages
- 4,233
- Location
- Moose Lake, MN
- Occupation
- Retired Cons't. Supt./Hospitals
My machine is a two-wheel drive, not four-wheel drive. I do not know what an axle tilt lock is.
Then you raise the boom a few feet the axle articulation lock for stability so the machine does not tilt on the axle center pin. If you try to drive on anything but perfectly level ground with the boom raised over just off the ground two opposite corner axles will be lighter as the other two carry the weight. No traction that way.
