I personally think it’s time to put this rig out of it’s misery, seems after 6 months of not moving in rainforest minus warm temperatures the rear axle is gone. Wife doesn’t want me to for all the work I put into it, money, time and memories for what it has done for us. Seems on turns the rear axle pops, after the 4th mountain pass it made a clunk in the axle when I down shifted, and spun up some when I up shifted. Three hundred twenty-eight miles till home can she do it... Went to refill and actually had second thoughts of spending the money, might have to drive the car back and get the other semi to tow it back in two trips.
Started the popping on the way out the driveway, thought it was the car not towing right. Will pop the motor off in the morning and see if I can manually shift it into higher gear in the morning after lifting it up and spinning the tires a bit to seat it in case something is stopping the sun gear.
