Willie B
I fell blindly at great expense into being the owner of an Economy 9 ton triaxle trailer. My son's buddy started the project in my garage. After adding 2000 Lbs of steel the manufacturer felt it shouldn't have, he lost momentum. I finished. Several years later I bought whatever I hadn't already bought, and some I already bought. It has been plagued with soft tires. Park it for a month, at least one tire is off the rim. This is never easy, as it is parked some distance from tools, seating a tubeless tire on the rim in a hurry wastes too much time. two, now three at a time I have bought new tires, on new rims with tubes. All six rims, and tires are less than two years. Put three new on Saturday. 100 miles later, on Sunday, carrying 12000 LBS I had a blowout in one of the new tires.
The dealer had lots of reasons it blew. Tubes cause heat, tires are twice as hot inside as outside, rough roads can't be traversed with trailers, (I was on route 7, the major highway in western VT) I was driving too fast, (50 MPH). These rims are a bad angle.
The blowout was spectacular! The car passing me at the moment must have suffered heart failure, or at least soiled underwear. Inside the truck cab it was loud as a cannon!. The steel rings buried in rubber against the rim were separated from rubber. Maybe 1/4 the circumference of the sidewall had blown off the rim.
I checked temperature immediately. None of the six tires were hot to the touch. all were equal in temperature, I'd guess 110 degrees F.
Was it a defective tire? Are tubes as evil as they say? Are the others soon to blow like this one?
Willie
Willie
