Trailer rebuild/repair thread
RZucker
Wherever I end up
Mechanic/welder
And another ugly one... the rear suspension subframe and cross sills are completely rusted out. DOT let them drive it home. Had a ton of fun with the plasma cutter today.:D
Cheap "old" Geezer
Coulda been worse, back in late eighties when was working Independent garage, side work at quarries and still dragging some to the house buddy shows up, 15 yard dump truck with a 10 yard pipe boom Midwest style pup, Look of Panic on his face. Hauling salt for the County Road department and trailer settled to the right side tires rubbing under cross member of bed. Old Trailmobile Reyco slider modified into the trailer some dozen years prior and salt cancer after it. Spent a full day jacking, blocking and digging out rust to weld in a NUMBER of patch panels to get that load off. Spent two weeks building the replacement based on the old pup specs so could just swap the hoist and body from bad to good. Was really hard to find steel to weld to, would strike an arc and blow holes, add more steel to keep equalizer rocker where needed to be.
RZucker
Wherever I end up
Mechanic/welder
What kind of trailer is that RZ? Its cost effective to fix it?
I gave them my quote for a total overhaul, They agreed to it. If it works for them, we're all happy. The rest of the trailer is in very good shape for a 1974 Brown, Built right here in Washington. The matching trailer had the same rebuild done just prior to them purchasing the set.
It is amazing how farmers will throw money at totally worn out trucks and trailers. There are so many rotten aluminum grain trailers running around here, but there is a DOT
officer now living here in town, he gave a bunch of warnings last year and very few heeded the warnings. Well harvest isn't far off and crying time is almost here.:D
I'm required to keep the company trucks in shape and compliance, John Barley Corn can do the same.
hvy 1ton
Lawrence, KS
I've seen some of those trailers in ID. One guy told me not to put too much grain on the front slope because some the rivets were missing. o_O
Cheap "old" Geezer
Cannot get away with that here, MoDOT Brown Shirts have no conscience as to shutting one down. A few Counties have their own as well also St Louis City so a Trifecta in most cases if you dodge one you likely will not another when on a quota screening day.
Cheap "old" Geezer
RZ, when did Brown dissolve? Were they bought up as Comet by another company? or By Comet? Utility was big on the Wide frame flatbeds too.
colson04
Delton, Michigan
This was the typical style of those days, many now are running wide spreads and steerables:
https://www.purplewave.com/auction/150421/item/K3170/1983-Clement-Trailers-Dump_Trailer-Kansas
I saw quite a few pup dumps like this running around Denver metro area and up in Western North Dakota.
Here in Michigan, we just shove more axles under them and lengthen the box like this:
Usually pulled by a quad axle dump for a total of 11 axles. Max GCWR 164,000 pounds
Short Double
Cheap "old" Geezer
Alloy hmmm
Did hauls to Comet in Spokane
They were absorbed by Great Dane
Still see the Dane emblems but different name there too
Not many old names still kicking
RZucker
Wherever I end up
Mechanic/welder
Short Double
That has got to be a tire scrubbing nightmare?
Mother Deuce
New England
Short Double
In Washington if it hasn't changed, you could license that to haul 105,500 gross. I am guessing that weighs about 48,000 empty. You could net 28 ton or so. With a 4 axle pup (self steering back axle and 4 axle tractor we could haul 14 ton in both ends and scale out legally. In the PNW bridge law was pretty much brought down the hill by Moses and it's sanctity shall not be questioned without incurring the wrath of someone with a badge and a book of really spendy tickets. However you almost never see a weight limited bridge
You guy's add axles. I was always trying to figure out how to build a airweight box out of tin foil and balsa wood frame rails...
