trailer rear support while loading
apm
Northeast Tennessee
I've just purchased a skid steer that weighs about 6000 lbs. I've got a 14,000 GVW trailer that's a bumper pull. Loading the skid steer with ramps lifts the back of the truck. The ramps have no "legs" on them.
How do most people support the back of the trailer when loading? I thought of a jack on each corner. Maybe just weld legs on the ramps? What do you guys do?
Greg
Get some angle iron and weld some support legs on the ramps. I can't remember how many ramps I have had repaired or adjusted over the years.
Hook the trailer up to your truck and measure the distance from the ramp where it connects to the trailer and weld some angle iron "struts/legs" to the ramps. That should help with your problem.
What kind of truck are you pulling it with?
andrewpond
canada
If your ramps are fixed and hinged then yes follow cm1995. But I use slide in/detached ramps and use trailer jacks on each rear corner. Ground/road aways seem different height. I use ones that pin to round coupler so if they get damage just unpin and replace.
OzDozer
Perth, Western Australia.
Semi-Retired ..
Carry some heavy-section wooden blocks such as 6" x 4" or 8" x 4" and place them under the rear of the trailer when loading and unloading.
Leave enough room to allow you to get them out when loaded, or to pull forward easily, to recover them after you're loaded.
buckfever
southwest pa
I second Oz's post. Thats a easy quick solution but if your looking for a legs on your ramps use 3" C channel. Make a U and weld it just above the where the ramp attaches to the trailer.
dsgsr
Monroe,Maine
Anything I can make $$ at.
A quick and cheap solution, cut a hardwood log 8-10" diameter. Load trailer, cut hardwood 2-4" short of distance of lowest part of trailer to ground. One for each side.
David
Aruba1
AL
Can you post pics of the trailer/ramps? with mine, I used to just drove my skid steer (8000 lb) with ramps not having no legs.
johndeere123
Nova Scotia
You could always make a set of legs that slide up and down with a pin holding them, alot cheaper and faster than using a jack on each side.
dixon700
pa
heavy truck mechanic
old-iron-habit
Moose Lake, MN
A ten inch block cut to length with one end cut 90 degrees and the other beveled a couple inches works well on my bumper hitch. Flat down, tapered up, you have a couple inches of adjustment to make up for uneven ground. I snug mine and pull ahead to tip them out. My 26,000 lb gooseneck has the built in jacks on the corners.
allie
NYc/NJ
buy 2- 1-1/2 by 1-1/2 by 1/4' steel tubing along with 5by6 1/4' plate and weld them up drill some holes put pin and your done
DDoug
Formerly digger doug
NW Pennsylvania
Thrash-A-Matic designer
and how to you remove them when the trailer is loaded ?
