Trailer brakes wiring
Discussion in 'Trailers' started by Gchartrand, Nov 24, 2019.
  1. Gchartrand
    Gchartrand Member
    Oct 25, 2019
    14
    Ontario, Canada
    I just replaced the trailer brakes on our 7K axle trailer. Does it matter what side the wires are plugged on the brake drum side? Cause right now I don't have very much brakes after assembling the new complete drum assembly.
    Is one ground and the other power?
    It's also a 2 axle trailer.
  2. AllDodge
    AllDodge Senior Member
    Apr 2, 2011
    1,568
    Kentucky
    Assuming electric brakes, it doesn't matter which wire, one power and other ground.
    It does matter if the ground side has a good ground back to the truck. It can be attached to the frame, but works best if there is a ground going back to the trailer connector.
    Did you adjust the shoes to fit the drum?
    Tags likes this.
  3. Gchartrand
    Gchartrand Member
    Oct 25, 2019
    14
    Ontario, Canada
    So I'll have to check those things you just mentioned this week once I get the chance.
    And no I never knew that those drums needed to be adjusted.
  4. AllDodge
    Apr 2, 2011
    1,568
    Kentucky
  5. willie59
    willie59 Super Moderator
    Dec 21, 2008
    12,405
    Service Manager
    Knoxville TN
    And adjust the brakes on those axles can be a challenge depending on how they are mounted. If the tube is above the spring (typical) the u bolts and bottom plate are right in the way, and if it's a drop axle, fa get about it, pull the wheels/tires off.
