Well guys I was able to install the track without splitting it.First I installed my track tensioner and idler, then I used the excavator to compress the tensioner. I then removed my top roller for more clearance. I used my skidsteer to lift the track and place it over the rear sprocket, then did the same with the front idler. It took a little work moving it around and so forth, but it was actually pretty simple.This track is like new with no wear at all.
After it was in place on the sprocket and idler I lifted the track in the center and installed my top roller, then tightened the track adjuster to specs.
The skidsteer with forks on it was a big help.
Thanks for all the advice, this is a great forum with tons of advice.
