Track pin coming out?!
Discussion in 'Excavators' started by Tyler Cohrs, Aug 16, 2022.
  1. Tyler Cohrs
    Tyler Cohrs Well-Known Member
    Apr 21, 2020
    55
    Glencoe, MN
    Noticed an issue on my Case CX490D machine today. Seen one of the track pads was sitting kinda crooked, then realized it was because one of the track pins has been working its way out. What typically causes this? Just a sign that the undercarriage is worn? Any tips for getting it back in or the correct way to fix this?? Thanks!!
    DMiller likes this.
  2. Bluox
    Bluox Senior Member
    Jun 19, 2010
    1,790
    WA state
    Loosen the track and run it about half way around on the sprocket and put in a new master pin.
    Bad Bob
    DMiller and bccat like this.
  3. Tyler Cohrs
    Apr 21, 2020
    55
    Glencoe, MN
    Is it the master pin which is moving on mine? Is that the most common one to move im guessing?
  4. James Sorochan
    James Sorochan Senior Member
    Aug 1, 2020
    278
    x-water & sewer construction Now farmer.
    Lethbridge county, Alberta, Canada
    It's the only one that you can pound out with a sledge hammer. The rest you need a big track press.
    DMiller and uffex like this.
  5. Bluox
    Bluox Senior Member
    Jun 19, 2010
    1,790
    WA state
    I can't see the rest of your tracks so don't know.
    But on well worn tracks that some times happens usually after the pin is improperly installed.
    What do the other end of the pin look like?
    Bad Bob
  6. uffex
    uffex Senior Member
    Jan 23, 2012
    2,985
    Admin
    Lincoln UK
    Good day
    Attached information also applies to installtion.
    Kind regards
    Uffex
    DMiller likes this.
  7. Tyler Cohrs
    Apr 21, 2020
    55
    Glencoe, MN
    Here is the pin viewed from the inside of tracks.
  8. farmerlund
    farmerlund Senior Member
    Nov 22, 2014
    963
    Farmer/ excavator
    North Dakota
    Looks like the rails are getting towards the end. You can always just weld around the ends after you get it back in place.
    CM1995, DMiller, oarwhat and 2 others like this.
  9. uffex
    uffex Senior Member
    Jan 23, 2012
    2,985
    Admin
    Lincoln UK
    Good day
    That appears to have been subject to bad installation practice, best to replace with expander pin if you can find a supplier.
    Kind regards
    Uffex
    DMiller likes this.
  10. Tyler Cohrs
    Apr 21, 2020
    55
    Glencoe, MN
    Do we think this actually is the master pin?
    DMiller likes this.
  11. Bluox
    Bluox Senior Member
    Jun 19, 2010
    1,790
    WA state
    Look at the rest of the pins and see if any are different.
    How about a picture of the idlers on both sides?
    Bad Bob
    DMiller likes this.
  12. John C.
    John C. Senior Member
    Jun 11, 2007
    11,709
    It probably doesn't help that the track is installed backwards on the machine. The burn marks on the rails also mean your chain is riding hard on some piece of the frame or maybe a frozen bottom roller.
  13. Tyler Cohrs
    Apr 21, 2020
    55
    Glencoe, MN
    Could you explain more about the track being backwards? How could you tell?
    DMiller likes this.
  14. Bluox
    Bluox Senior Member
    Jun 19, 2010
    1,790
    WA state
    Looks like the other is too, if you don't travel a lot won't make a lot of difference at this point.
    How about pictures of both front idlers?
    Bad Bob
    DMiller likes this.
  15. John C.
    Jun 11, 2007
    11,709
    One of your photos show a sprocket which is at the back of the track frame. The big ends of the links are looking back at the sprocket and should be looking forward at the idler instead.
  16. DMiller
    DMiller Senior Member
    Feb 21, 2010
    13,199
    Kinda Retired
    Only the master will clear the bushing ends, are two large washers taking up the spaces in the master link end.
    shopguy and DB2 like this.
  17. Tyler Cohrs
    Apr 21, 2020
    55
    Glencoe, MN
    Here's some additional pics...
    DMiller likes this.
  18. John C.
    Jun 11, 2007
    11,709
    Looks like you have pins working out on both sides. Judging from where the idlers are and the condition of the links, I'll guess that someone cut a link out of each side to make the chains run longer. The last photo shows the correct direction of the chains.
    oarwhat, CM1995 and DMiller like this.
  19. Tyler Cohrs
    Apr 21, 2020
    55
    Glencoe, MN
    Machine is a 2016 with 7,000 hours if your wondering
  20. DMiller
    Feb 21, 2010
    13,199
    Kinda Retired
    If were OE rails at around 4000-5000 hours depending on materials aggressive qualities they were worn to limits.
    John C. and DB2 like this.
