Ridgerunner1
I have a cat 304. I found a good set of used tracks, everything matches except I'ts 74 links, mine is 72 links. Is there enough adjustment to use the longer tracks?
John, Thanks for the help, however these are rubber tracksThat's a big jump. If they are the same pitch, the adjuster cylinder will be all to way at the end of its stroke and the tracks will still be loose. You can cut a couple of links out and make it work. I'd probably take one and try it and if still too long take the second one out.
