Huh, I'm not finding anything on that unit, Google has let me down. There are about a hundred different makes of those cutoff valves with filter though. It could be the coil, it's possible you have a restriction somewhere between the tank and this valve, the filter inside this unit could possibly be plugged, etc. Does the convertor that this valve is attached to ice up at all?
For purposes of testing, keeping in mind it would be a safety violation to operate without this cutoff valve in the system, I would remove this valve and connect the hose directly to the convertor and try running it. If it then runs fine for an extended period, replace the whole valve they're not that expensive. If the problem still shows up then it's time to look at either the supply from tank, or the convertor. That's assuming it's not an ignition problem!
