Waffelwhiffer
I have an OLD Towmotor forklift with a 4000lb capacity. It's leaking hydraulic fluid from the top of the mast cylinder. I managed to tighten up the packing nut some, but it needs to be re-packed.
My question is this:
Can I use corrugated ribbon valve stem packing on top of the remains of the existing packing?
Or would that make things worse?
I saw an article about installing new packing rings without disassembling the cylinder (just cut them and stagger the rings), but finding the right rings for this beast could be a problem. Believe it's left-over from WWII.
I'll post the ID plate info later - just need to know about the packing issue for now.
Thanx!
Thanx!
