towing 15,000 with f-350
Discussion in 'General Industry Questions' started by thebig450es, Nov 15, 2010.
  1. thebig450es
    thebig450es Well-Known Member
    Sep 25, 2009
    199
    pittsburgh
    I know a cdl is required with this weight, but how many people tow about 15,000? and do you have any pictures of your loads and how it sits on the trailer and truck?
  2. monkey
    monkey Well-Known Member
    Aug 4, 2010
    136
    lousyana
    you need a cdl :eek:
    I guess I've been lucky for the last 10 years
    I haul my dozer D-31 on a tandem dually trailer with a pintle ring. I beefed up my receiver :tong
    I have a 99 F-350 4x4 drw, I did upgrade the wheels and tires to 19.5...the load capacity of the tires are like 5200 lbs. double of what the stock tires are
    main thing is load distribution and having good brakes on the trailer
  3. killowatt1
    killowatt1 Member
    Sep 23, 2010
    10
    heart of dixie
    i tow a 580 super e on a 30 ft. goose neck with 10,000 lb duels with a 2008 f250 sd and have no real trouble . but pulling is one thing stopping is anouther,need good brakes on both axles of trailer.
  4. buckfever
    buckfever Senior Member
    Aug 12, 2010
    813
    southwest pa
    pull a hudson gooseneck behind a F-450. Load it with a jd 50 zts and a newholland ls180. She's heavy but pulls and stops great.
  5. Speedpup
    Speedpup Senior Member
    Jul 6, 2007
    1,214
    President and all else that needs done!
    New York
    doubt it can do it legally and if you get in an accident it will be a lawyers field day on you. What is the gross combined weight rating of a F-350?
  6. Speedpup
    Jul 6, 2007
    1,214
    New York
    doubt it can do it legally and if you get in an accident it will be a lawyers field day on you. What is the gross combined weight rating of a F-350? May be a 350 can look on the door for the plate with the ratings.
  7. rutwad
    rutwad Senior Member
    May 13, 2007
    263
    GCWR lbs (kg)
    Engine Axle Ratio Manual Transmission Automatic Transmission
    F-250/F-350 SRW
    5.4L
    3.73 15,000 (6,804) 16,000 (7,257)
    4.10 17,000 (7,711) 18,000 (8,165)
    6.8L
    4.10 20,000 (9,072) 21,000 (9,525)
    4.30 22,000 (9,979) 23,000 (10,433)
    6.0L 3.73 23,000 (10,433) 23,000 (10,433)
    F-350 DRW
    5.4L
    3.73 15,000 (6,804) 16,500 (7,484)
    4.10 17,500 (7,938) 18,500 (8,391)
    6.8L
    4.10 20,500 (9,299) 21,500 (9,752)
    4.30 22,500 (10,206) 23,000 (10,433)
    6.0L
    3.73 23,500 (10,659) 23,500 (10,659)
    4.10 23,500 (10,659) 23,500 (10,659)
    F-450
    6.8L 4.88/5.38 26,000 (11,793) 26,000 (11,793)
    6.0L 4.30/4.88 26,000 (11,793) 26,000 (11,793)
    6.0L* 4.88 28,000 (12,701) 30,000 (13,608)
    F-550
    6.0L 4.88 26,000 (11,793) 26,000 (11,793)
    6.0L* 4.88 28,000 (12,701) 33,000 (14,969
  8. Colorado Digger
    Colorado Digger Senior Member
    Dec 3, 2008
    1,169
    Carbondale,co
    yes you can
    i hauled my first hoe a cat 307b for years behind a 2000 powerstroke with drw and 4:10's. it is possible, is it my favorite thing to do? no. even hauled with a 1 ton pwerstoke with 3:73"s and srw. no... not fun. but yes it is possible
  9. Dualie
    Dualie Senior Member
    Feb 23, 2007
    1,371
    Nor Cal
    The first link is around 13,000 Lbs ish behind the truck.
    http://pic20.picturetrail.com/VOL1261/4303498/16210556/278337904.jpg
    This little bugger is deceptively heavy. Its a "custom" 5 horse trailer normally goes behind a bus conversion motorhome but due to its $1.3M worth of unreliability my trusty 2000 F-350 saves the day often. trailer weighs around 21,000 to 24,000 fully loaded and pulls surprisingly well for what a flipping monster it is.
    http://pic20.picturetrail.com/VOL1261/4303498/16210556/324530148.jpg
    No weight distribution bars being used in any of these shots. Just the factory receiver hitch with a 24K rated 2 5/16" ball and ball mount.
    Maintenance is the key if your going to be performing these stunts regularly. NOTHING is questionable when preforming these acts. Brakes, suspension, tires, steering all have to be top notch at all times.
  10. Dozerboy
    Dozerboy Senior Member
    Jan 18, 2006
    2,205
    Operator
    TX
    Thats a nice horse trailer though I surprised you tow it with the factory hitch. I know guys bending HD Reeae ETC hitches that pull heavy. That might because most of then are using weight distribution bars. They sure put a lot of TQ on hitches.
  11. Dualie
    Feb 23, 2007
    1,371
    Nor Cal
    Its not my horse trailer, personally a black skinned livestock trailer is about the dumbest thing i could think to build. Especially since theres just about $1M worth of show horses in there. It carrys most of its weight on the axles so most of the work is strait draw bar pull. probably only 4K pin weight MAX.
    My own personal opinion is if you need weight distribution bars you should have bought a gooseneck.
  12. Aliate
    Aliate Senior Member
    Feb 17, 2009
    318
    Seattle, WA
    lol if you did that around here you wouldnt make it 2 blocks, I got pulled over in my mack dump truck pulling a cement mixer because one of the safety chains fell off.
