Cranes & Derricks in NYC
Too early to determine what the actual cause is, only can speculate as to what happened, could have been as simple as the rigging used to secure the collar failing and then the domino effect after.
I've read here on/off, have a heavy commercial construction background, most of it working in Manhattan and other borroughs in addition to having been an equipment operator in NJ prior to that. I was at the senior project manager level when I left the business, having worked my way up the ranks from the bottom.
Maybe you are familiar with the procedures in NYC for crane installations , but I can shed some light on this if not. I have done quite a bit of work with cranes, mostly hydraulic rough terrain types up to 300 ton, have been on 2 sites with Cranes Inc big 500 ton hyd, + some crawlers on derricks and tower cranes on several other sites.
Typically, a project manager representing either the sub contractor, like the steel erector or concrete sub, will size up and own the crane for the job. Sometimes the Const Mgr./General Contractor does it, depends on how the job is set up but can be a real pain when you have to schedule picks from a crane that is provided by the CM/GC or a sub. NO matter who does it, they have to use a licensed professional engineer to design the installation and confirm the size and configuration, and in this case, I do know the particular designer of this installation quite well, as well as the outfit that leased the crane who were also always a pleasure to deal with in my experience having done numerous installations in the past with both. There were only a few people in NYC that did the "expediting" or crane permit filings with the city agencies, specializing in this area and maintaining contacts, kind of niche business in that respect.
The licensed professional engineer in this case, would have filed an application with the City of New York Dept. of Buildings, and City of NY D.O.T. for approval by their plan examiners The permit is issued and the associated paper work is copied to all appropriate parties including the operating engineer on the crane. The city does not like hydraulic cranes placed on the streets, like the mobile rough terrain types, and are hesitant to approve them for use and issue permits in many situations, they have to close lanes for the outriggers, restrict traffic, pedestrians, there are just a myriad of reasons why, some including safety as well as previous accidents. They seem to prefer a crane installation to be within the footprint of the building or within the sites work limits, inside the fence, so a tower crane would usually be more easily approved, as it is close to or within the new buildings footprint, no impact to traffic, still have to flag and stop pedestrians if hoisting over a walkway even if it has a sidewalk bridge protective structure installed over the walkway.
Cranes & Derricks may elect to inspect and do show up to inspect an installation, with hydraulic types placed on the street, outrigger dunnage is a big item to inspect. The operator will also review the drawings and technical information to make sure everything is in order, have to remember these guys do not appreciate putting their city of new york crane licenses and other certifications at risk, all the operators I've had on my payroll were copied on the information as soon as the crane arrived, or they arrived on site for the installation. None that I have known would take chances there for any reason. There is a catch to this, they certainly can't see the condition of the rigging being used when in the house above, and if someone uses something compromised, the operator just won't be able to see it from one of these rigs, they rely on and trust the people below doing the rigging. I have seen many times where things that were rigged, were very risky and needed to be corrected. Slings, choker cables, etc. have to be in 100% condition, yet a contractor will use these items if well worn as I have often seen unless someone stops them.
I think it is important to realize that the operator of this crane along with his riggers would have been familiar, or should have been familiar with the details of the installation, per the drawings created by the engineer, and approved by the city agencies, it is hard to believe that either the operator, riggers and the engineer who designed the installation would have missed an important detail like improper or missing connections to the superstructure, or that the crane was installed with deficient connections to the building violating the drawings, this engineer would have inspected all of this on site, he is a very hands on, field orientated person, as are his people. I don't see that happening, unless someone did something unbeknownst, but even the operator should have been attentive to something like this if it were to occur.
The seemingly dumbest things can and will occur, in early Sept. '99, the hurricane Floyd came through the city, on Sixth avenue, 23rd-26th I forget now, but Turner was doing a typical reinforced concrete, 30 story job, where they had a 777 or 4100 Manitowoc crawler on a derrick, tower type mast with luffing jib, (terminology is getting rusty for, may need correction), to make the reach needed, building was close to or topped off. They folded up the crane and secured it, the storm passed, the operator ended up trying to unfold the boom/luffing jib, with the restraints still in place, it pulled the entire tower/mast & boom over backwards, I heard the crash from my job site and ran over a few blocks, it killed a local 608 carpenter. They lashed it down, but never heard as to why they were not released before he powered up, or what happened, seemed foolish, but hard to say without being involved.
Every installation in the city is probably going to be heavily scrutinized now. I also think after the investigation, the procedures for erecting, climbing and rigging this type of crane will be reviewed. There also master rigger licenses granted to people who have to pass a detailed test, NYC is extremely stringent on these things, crane installations and rigging are taken very seriously, D.O.B. cranes and derricks, D.O.T. and the B.E.S.T. squad are the leading agencies for safety. This is a typical reinforced concrete residential structure going up, tower is on a foundation and tied off the to the building. The risk when climbing and adding sections, is certainly dependent on the rigging holding the collar, and there was no back up for what occured. I'm curious about the foundation, but obviously this design was not for a stand alone configuration or it too was compromised by what occured. Under the streets or below grade you can have all kinds of conflicts and things to deal with, if you are close to a subway, you may also need MTA and Port Authority approvals, so maybe a deep foundation for the crane was not possible here and it relied more on the building's superstructure, lot of possibilities to consider in the design, working in Manhattan can be full of challenges to say the least. 12,000 lbs. falling from 10-20 stories could have not only sheared the connections to the building, but also destroyed the foundation and connections even if it was strong enough for stand alone at the height it was. Most of these are stand alone until the building reaches some height then they attach to the building, might have been engineered like that, after a certain tower height, there will be enough superstructure erected, with 28 days allowed for the concrete to cure allowing for connections to the tower to be made that would allow it's height to be then raised. We worked with one set up on cantilevered dunnage beams off the 10th floor of a bldg., in '03 at 640 5th avenue across from St Patricks cathedral, that was a real unique set up, have a few photos of that one.
I think that an alternate detail for installing additional temporary connections to the tower from the superstructure, which would keep the tower from moving or falling in the event the rigging failed on a pick like this while raising the tower to a new height and installing the required collars, will be considered for a requirement. The back up connections for tying back the tower would have to be pre-coordinated into the structural design of the building, and allow for no conflicts with the tower raising and other procedures. It is evident that there is no back up or secondary connections used currently after seeing an event like this, very possible for some manatory changes in procedures, structural design, approval and inspection, of this kind of equipment by city agencies.
One thing about NYC projects, all have compressed schedules and are run by super motivated project managers, executives, and unrelenting owners who just keep upping the anty with pushing these compressed schedules, things get too tight and they push and push production to the max at all times. Usually don't like interupting that 3 day per floor cycle on these concrete jobs. This high paced environment can be a breeding ground for safety issues, they had a lot of unrelated violations already, but are typical for this type of job. Even with that in mind, the crane installation should not have violated the design by the engineer and what was approved on the permit. I strongly suspect the rigging used and procedures followed during the pick will be the focus of the investigation.
http://www.nytimes.com/2008/03/17/n...1221364800&WT.srch=1&excamp=GGGNcranecollapse
