Torque
Discussion in 'Dozers' started by AllDodge, Jan 16, 2020.
  1. AllDodge
    AllDodge Senior Member
    Apr 2, 2011
    1,743
    Kentucky
    D3B lift cylinders and manual list 800 ft lb +/- 80 on the piston bolt. Bolt is a 7/8-14 thread
    My torque wrench goes to 600, so looked up turn to torque and it list
    Turn torque = pre torque 480 ft lb then 1/3 more
    Torqued to 480 then using a 3/4 impact was only managed to turn the bolt another 30 to 35 degrees. The bolt does have a nylock insert so thinking it won't back off, but not 100%. Need either a way to get it an additional 30 degrees or is it good enough
  2. Welder Dave
    Welder Dave Senior Member
    Oct 12, 2014
    4,170
    Does it max out your torque wrench? I think I'd use a long bar on a socket than depend on an impact wrench. Not sure if the bolt would be the same as a track bolt. Maybe you could take it to a shop to have the nut torqued?
  3. AllDodge
    Apr 2, 2011
    1,743
    Kentucky
    Yes, my wrench goes to 600
    Could look around for someone which can torque it, or haul to Bowling green to CAT
  4. Mobiltech
    Mobiltech Senior Member
    Jan 15, 2014
    1,152
    Sask.
    If you have a 3/4 drive ratchet or breaker bar that you can get just over 4 feet of handle on hang a 200 lb man off the end of it and it will be 800 lb/ft .
    DMiller, Tenwheeler and kshansen like this.
  5. AllDodge
    Apr 2, 2011
    1,743
    Kentucky
    Do have a 2 ft 3/4 ratchet.
    Do have the shaft, bolt and piston marked, so will give the bar a try, thanks
    Just need to find a bar that will work, have mostly thin wall lying around
  6. Coy Lancaster
    Coy Lancaster Senior Member
    Dec 19, 2014
    1,253
    service tech
    Arkansas
    I like the 3/4 rachet and 6ft cheater pipe method myself
    DMiller likes this.
  7. Nige
    Nige Senior Member
    14,987
    I'd prefer to pull on a breaker bar than a ratchet, unless the ratchet is way over-capacity for what I think I'm likely to be pulling.
    If you didn't replace the Nyloc nut the perceived wisdom is to add some Loctite Threadlocker to the threads on the rod before installing the nut. I've seen them come loose in the same location on cylinders for other applications.
  8. AllDodge
    Apr 2, 2011
    1,743
    Kentucky
    Have to agree, don't see a 2 ft ratchet being made to take 800. Going to call around to see if I can find someone
    DMiller likes this.
  9. Nige
    Nige Senior Member
    14,987
    It's difficult to find hard and fast numbers but 800ft.lb. appears to be close to the limit of capability for a 3/4" drive ratchet.
    The issue as I see it is that having tightened to 480 then going plus 60 degrees from that you have no idea what final torque you are actually pulling. You HOPE it is around 800, but in truth you don't know.
    DMiller likes this.
  10. John C.
    John C. Senior Member
    Jun 12, 2007
    7,882
    It's a D3B lift cylinder, not a 330C stick cylinder. Put some red thread locker on it and pull what you can get. 600 foot pounds and a little more will work fine. I've made slugging wrenches out of 3/4" thick plate and used a twenty pound hammer to loosen the nut and pull them up tight.
    DMiller and Nige like this.
  11. kshansen
    kshansen Senior Member
    Mar 11, 2012
    8,297
    Central New York, USA
    Or there is this option:
    https://www.homedepot.com/p/URREA-3...VJv_jBx3GjgUXEAkYDyABEgKzXfD_BwE&gclsrc=aw.ds
    No idea of quality but at least there are no pins swivels or other moving parts to fail. Never purchased one from this place but for the price a one time use might make it worth the gamble. Believe I have an actual name brand one out in the tool box. It would cost me more that this one for shipping.
    Sorry if first link was the wrong one!
    DMiller likes this.
  12. AllDodge
    Apr 2, 2011
    1,743
    Kentucky
    Drove up to Froedge in T-ville, where I had my 955 lift cylinders repaired and let them torque. All good now, going to put them back together now
    Thanks for bouncing the ideas
    DMiller, Nige and balls2go like this.
  13. Mobiltech
    Jan 15, 2014
    1,152
    Sask.
    For future reference I have a westward 3/4 ratchet 30 years old and I don’t think I ever use it without a 4 foot pipe extension. It’s held up to 2 guys pulling on it many times. Probably surpassed 1800 ft lbs a few times.
    DMiller likes this.
  14. AllDodge
    Apr 2, 2011
    1,743
    Kentucky
    Mines a Craftsman, about 20 years, and it would probably hold up due to its was before Sears started going down. Just a maybe though
    DMiller likes this.
  15. FWD
    FWD Well-Known Member
    Jan 7, 2009
    146
    Barron County, Wi
    I've got an old Proto ratchet purchased about 40 years ago. A few years ago I needed to get some difficult bolts out on an IH TD-15C. Had a long pipe on my breaker bar and the breaker bar bent. Put the pipe on the Proto ratchet and got everything apart, no bends no break.
    FWD
    DMiller likes this.
  16. D6c10K
    D6c10K Senior Member
    Apr 1, 2008
    594
    Iowa, USA
    I use a torque multiplier (planetary gear type). The one I have is rated to over 2000 ft lb. I know I've twisted off rusted track bolts with it, driving it with only a ½" ratchet.
    DMiller, balls2go and ttazzman like this.
  17. ttazzman
    ttazzman Well-Known Member
    Sep 10, 2010
    194
    missouri
    ^^^ +1 on a torque multiplier ....i was begining to wonder if anyone used one on here
    DMiller likes this.
  18. nicky 68a
    nicky 68a Senior Member
    Apr 14, 2013
    592
    england
    I’m currently pulling up new D8 track bolts.Book says 500lb plus a couple of flats.I mark them up and then pull up the old fashioned way with an 1” t bar and 6 foot tube.
    I’m curious as to the final setting?
    DMiller likes this.
  19. John C.
    Jun 12, 2007
    7,882
    I've always just barely been able to pull new track pad bolt up that way. By the end of the third pad I was looking for help to share the pull. I went to using a four to one multiplier to get to that last flat on turn.
    DMiller and nicky 68a like this.
  20. RZucker
    RZucker Senior Member
    Jul 7, 2013
    4,102
    Mechanic/welder
    Wherever I end up
    I always kind of figured that the torque-then turn specs on track shoes was best left to a big impact wrench to turn the final angles. Both for the speed and not wearing yourself out. The only ones I will hand pull are alligator master bolts so I have a feel of what's going on.
