Toro Dingo TX425 Muffler Bellows flex pipe keeps cracking
Discussion in 'Mini Skid Steers' started by PeterG, Jun 12, 2022.
  1. PeterG
    PeterG Well-Known Member
    Apr 14, 2015
    219
    Landscape Construction, General Contractor
    Seattle WA, United States
    I have 1600 hours on my Dingo which I've had since 2012. Mostly a fantastic machine. However, my maintenance records show the muffler has been replaced five times. This last time in less than a year. Toro replaced it under warranty. The muffler itself is fine. The issue is the steel corrugated looking flex bellows pipe between the Kohler gas engine and the muffler. first question is what causes this to break? The engine has just been replaced, not bad motor mounts. Idle is 1275-1320. Maybe it's just bad quality. The muffler flex pipe breaking is a known Toro problem. I would like to get a cheap better fix as the mufflers are going up over $400 now. The two pipes are 1.5" dia on each side of the bellows. I tried to insert a piece of Surebilt flexible galvanize steel exhaust pipe with hose clamps and exhaust sealant. Wasn't going to work well. Would prefer to find steel flex bellows for 1.5" dia pipe and get someone to weld it in. The fancy stainless steel Car flex pipes don't look good either. Any ideas?
  2. PeterG
    Apr 14, 2015
    219
  3. PeterG
    Apr 14, 2015
    219
  4. PeterG
    Apr 14, 2015
    219
    Here's the machine for your reference
  5. ianjoub
    ianjoub Senior Member
    Jun 22, 2018
    1,012
    Homosassa, FL USA
    Is the muffler rubber mounted? Maybe too much flex from bad mounts? Maybe not enough flex from rigid mount muffler and rubber mount engine?
  6. hosspuller
    hosspuller Senior Member
    Aug 27, 2014
    1,770
    North Carolina
    Just a thought ... Looks like the bellows is doing duty as an elbow. That uses some of the flex. Sort of like a spring that is compressed solid. Can you use a rigid elbow and keep the bellows straight?
  7. Jonas302
    Jonas302 Senior Member
    Jan 4, 2015
    1,051
    mn
  8. digger doug
    digger doug Senior Member
    Nov 2, 2011
    707
    Thrash-A-Matic designer
    NW Pennsylvania
    Yes. look at ultralight air-o-plane exhaust systems, they use a ball & socket with 3 springs.
  9. PeterG
    Apr 14, 2015
    219
    Thanks for all the info. Yes, the muffler has no rubber mounts and the bellows is pretty much like an elbow. There is some talk of excessive exhaust heat or something (engine running lean, idle too high), engine isn't cooled off enough before the engine is shut down, but I think it is just vibration and design. Regarding the noise level, if you see slight exhaust coming out where the muffler pipe attaches to the engine header pipe, does that add to noise level? I tried some JB exhaust sealant before I put the clamp on. Is one clamp enough, or is two better?
