Spud_Monkey
Your six
Decommissioned
I picked up a Harbor Freight special a month or so ago. The mini tire changer, on sale with a coupon for under $40. This thing is handy. Both front tires on my lawn tractor rotted out and seeped air through the sidewalls. I bought 2 new Carlisle lawn tires for $50 and finally found time to change them out this afternoon. Super simple. I watched a YouTube video on how to use it and had both tires changed out in under 30 minutes. I did have to use a shot of ether to set the beads but the task was a breeze overall. I got them back on the tractor just as the rain started coming down again.
Now to pickup new tires for my dad's golf cart. He drives it so much, the tires are showing cords. I also have 2 wheel Barrow tires to replace and a snowmobile dolly with a bad tire as well. Always something.
I wouldn't use a bead blaster or ether for the tires that small, a small ratchet strap or rope with a rod to tighten the rope wrapped around the tire tightened till it pushed the bead to the sidewall and air up.
colson04
Delton, Michigan
I tried that today and the beads kept smushing inwards, away from the bead seat on the wheel. I said phoney, grabbed the ether and gave it a shot and lit with the torch. Worked great on both and was faster then putting the strap around it. Normally, small tires like that will seat easily without any persuasion, but these two tires didn't want to cooperate today.
colson04
Delton, Michigan
I tried changing my garden tractor front tires without one last year. It turned into a real poop show....I ended up buying the tire changer and it's an amazing tool. It makes tire changes a breeze and I smile everytime I use the tractor without having to inflate the tires first.
I crushed the rim on a lawn tractor trailer this past spring trying to pry off the bead to replace a tube. It was just a thin piece of stamped sheet metal and any side pressure crumpled it. I replaced both of those tires with a flat free wheel combo. Now I don't have to worry about that trailer.
chidog
kent, wa
Crane ? What will it lift? There is no counter weight ! Nice idea otherwise. Looks very easy to tip over.
I'd love to have a crane on the yard like that. We have a Gradall 534 that's handy as a shirt pocket sometimes but that crane is the ticket.
DIYDAVE
MD
Sure would be easier to just spot weld the item you're working on to a set of sacrificial jaws on a standard vice... Man sure has a lot more patience than I do!!!
