CascadeScaper said:
Awesome man! I'm getting nervous about getting my CDL, I think I"m going in about 2 weeks for my written test (permit), which will be easy, but the pre-trip inspection is going to be the hard part. How many documented hours of driving with your permit do you need?
In PA you don't need to prove ANY documented hours...
. They've recently started doing that for a regular drivers license, so maybe they will be doing it for CDLs as well. I got my permit on my own, then went to the local commercial driving school because they offered a "customized", pay-by-the-hour course. I spent about 32 hrs. behind the wheel (in the yard, and out on the road), including the couple hours to take my test. Spent a few more hours learning the pre-trip and airbrake.
I'm glad I did it this way, since I knew EXACTLY what to expect on the test before I got there. I even got to run the exact test couse a few times with my instructor in the weeks leading up to the test.
The pre-trip inspection isn't so bad. Especially since you're already running equipment and (hopefully) are already doing some sort of "pre-trip". Your state CDL manual should have all the stuff you need for the pre-trip, so it's just a matter of studying. Since I went through a driving school, they had their own study guide, which I felt was a little easier to understand than what was in the state manual. You'll also find that once you learn something, it applies to other areas of the truck as well. For example, once you have the brake inspection for the front axle down, it's almost the same for all the other axles on the truck. Same with tires, lights, etc. Also you will become very familliar with the phrase "secure, no visible damage, no missing nuts"...:wink2
The PA test is divided into three parts:
1) knowledge: pre-trip inspection and airbrake
2) skills: straight-line backing, and driver's side parallel
3) over-the-road
There are a few things you can do to get an "automatic" failure (hit a curb, blatant traffic infraction (speeding, run a red light, etc.)), but other than that, it's done on a "points" system. You accumulate points for your mistakes, and as long as your under the limit, you pass. They don't expect you to be perfect, but that's what I was shooting for. Didn't quite make it...
I assume other states have a very similar system.
Joe
