azvacs
OK, Here we go again. I have replaced the entire wiring harness. Brand new. As soon as i hook up the battery, the fuel pump starts to do it rattle thing, even without the key in. Put the key in and turn it to start and it starts and runs fine. Then i try to shut it down and it wont. Turn the key off, still running. Take the key out, still running. Disconnect the negative battery terminal, still running. The way i got it to shut down was to disconnect the round connector that runs up to the lap bar proximity switch.
WTH is going on?????
Need help from the Tak GURU’s
