Clawed Backster
I've got an old Michigan wheel dozer with 29.5-25 Michelin radial tires on it. A previous owner filled them with liquid. The tires seem to be very old, as the tread crumbles away pretty badly on rocky ground. The machine weights 63,000 pounds, and I would estimate that 70% of that weight is on the front axle. I don't know what pressure to run, and I feel that the biggest danger is excessive sidewall flex causing them to split due to their age.
BTW, this machine gets very little use, as it is just used around my property for little projects, so no, I won't be replacing them with newer tires.
Opinions?
Opinions?
