oceanobob
Got the U17 as it has those expando tracks to allow access into back and side yards. For its size it has quite an ability.
Two questions: is a 36" tilt bucket too big and how does the tilt cylinder work off of the factory hydraulics which are able to run a hammer?
But one thing about the mini ex (which is missing from the backhoe world) is what we call a "squeegee". A squeegee is a piece of cutting edge or other flat strip steel on a bucket to help quickly trim the grade to exact elevation such as when prepping base for paving with concrete or asphalt. The one for the backhoe is 4' wide, I have seen em 6' wide. The backhoe outriggers are adjusted to add a slight angle or compensate for the angle - either way the sqeegee will do a decent task readily.
But the mini excavators dont have tilt side to side - thus was considering purchasing a tilt bucket as the contrivance to act as a squeegee.
Smallest one I can find is 36" wide and the big kubota bucket that we got with the machine isnt even close to this size. I figured it the cleanup bucket volume is too big I can refrain from filling it, and I could also put a 45 degree blockoff baffle in each corner of the bucket (to make it more like a tapered scoop) to reduce the volume.
OR
Get a tilt mechanism and put on a curved blade only to save the dead weight.....
The latter idea isnt as useful but will have its place.
Any idea how the tilt ram works with the boom hydraulics given these are only known by us to work an attachment like a hammer breaker? I have read a lot about how to install a thumb and it appears the factory hydraulics isnt quite the solution for a thumb unless some form of control valve with a relief port (some words about crossover and volume issues etc etc) Seems the tilt ram might fall into the category of the ram for the thumb.
The hydraulic motor style swivels offer more articulation (like 180 degrees) whereas the tilt done with a ram seems to be 45 each way for 90 degrees of motion. Maybe these radial hydraulic contrivances have non biased flow (ergo no displacement issues such as a ram) and is more suited to the hydraulic system on the machine / application. But not sure if these are made small for this little machine.
Having an independent swivel that fit any bucket or maybe remove the swivel for routing digging....this seems to be have more forethought.
OR
