tnc110. After the field mechanic installed the box with the clunk the first time I pulled the box again and took it to Cat dealer to correct. Re installed and clunk was still there. Dealer(Cashman Reno) sent number one man out twice and he determined something was still wrong in the box. He came back out, pulled the box, went back to shop and found that the shimming instructions in the repair manuel were reversed(wrong?). He put it together right, I reinstalled it and it is fine. To answer you question, Taking the box out is not bad, you need a torch for the loctite and a crane or backhoe and a bunch of the right caps. Im not much of a mechanic so I wont go inside the box. It seemed always like a worn ring gear or pinion but the problem was pinion end play due to missshimming. I always knew my problem was in the box because I knew when it started(at the reseal). Maybey this information is helpfull.
