threads
Discussion in 'Skid Steers' started by jsmith6752james4now, Jul 3, 2020.
  1. jsmith6752james4now
    jsmith6752james4now Well-Known Member
    Jan 21, 2020
    92
    Toughkenamon, PA
    Can the treads on the end of the cylinder end be chased? I had a tough time getting the seal end off and now it on goes in about 4 turns. I hope I don't have to buy a new cylinder tube. thanks
  2. Ct Farmer
    Ct Farmer Senior Member
    Dec 9, 2016
    323
    Connecticut
    Internal or external threads? On external I’ve often used a knife edge file to carefully clean out burrs.
    56wrench and DMiller like this.
  3. jsmith6752james4now
    Jan 21, 2020
    92
    Toughkenamon, PA
    It's not the gland threads it'e the tube end threads.
  4. Ct Farmer
    Dec 9, 2016
    323
    Connecticut
    Right, so is the tube threaded on the inside or outside?
    Perhaps post a picture so we can see what you are dealing with.
  5. jsmith6752james4now
    Jan 21, 2020
    92
    Toughkenamon, PA
    The treads are on the inside.The gland screws into them.
  6. DMiller
    DMiller Senior Member
    Feb 22, 2010
    11,293
    Almost Retired
    There are thread files available can get them from such as MSC, Grainger, I found a set with tip end files for internal threads as this at McMaster Carr. Can take a conventional Tap of that thread TPI and use it sideways as a file if the threads are boogered up.
    https://www.mcmaster.com/thread-repair-files/
    56wrench, DB2 and Ct Farmer like this.
  7. Ct Farmer
    Dec 9, 2016
    323
    Connecticut
    Yup, thread files, a tap the right pitch, just carefully scrape one flute though the damaged area. I have also used a thread cutting tool from the lathe and scraped with that. Carbide is best if you have it. I’ve also got some really fine hooked jewelers files that are useful for this sort of thing.
    You probably only have one small area that is damaged right at the point it starts to hang up.
    Though not likely there is a chance the tube is no longer round or has been slightly damaged distorting the thread.
  8. jsmith6752james4now
    Jan 21, 2020
    92
    Toughkenamon, PA
    good info...thanks
    DMiller likes this.
  9. jsmith6752james4now
    Jan 21, 2020
    92
    Toughkenamon, PA
    How do I determine the thread size?
  10. Ct Farmer
    Dec 9, 2016
    323
    Connecticut
    You need a thread pitch gage. Depending on machine could be SAE or metric.
    Flat Thunder Channel and DMiller like this.
  11. mikebramel
    mikebramel Senior Member
    Jul 16, 2012
    1,612
    milwaukee
  12. jsmith6752james4now
    Jan 21, 2020
    92
    Toughkenamon, PA
    Does anyone have the torque spec for the lift boom cylinder nut on a 1840 case? I have a manual for a 1839? I need one for a 1840.....thanks
