This is a skidder right?
Discussion in 'Forestry Equipment' started by ippielb, Nov 25, 2020.
  1. ippielb
    ippielb Senior Member
    Mar 31, 2014
    432
    Saskatchewan
  2. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    2,876
    Oklahoma
    Like parting it out for scrap price. You may lose money
    Mother Deuce and DMiller like this.
  3. Mobiltech
    Mobiltech Senior Member
    Jan 15, 2014
    1,201
    Sask.
    It is a skidder with a directional drill attachment. The drill would be worth something if it had the drill stem sections with it.
    DMiller likes this.
  4. ippielb
    Mar 31, 2014
    432
    Saskatchewan
    Do you have an idea what model skidder it would be? If it came down to scrap price I’d like to calculate how much it weighs to see if one could get their money back.
    That’s what I figured it was on the back. Curious to see what model drill it is and see if there is actual value.
  5. Willie B
    Willie B Senior Member
    Jan 3, 2016
    2,011
    Electrician
    Mount Tabor VT
    Is it a GM from Dyna Hoe? Has a look of similarity to Dyna Hoe, BIG backhoes.
    DMiller likes this.
  6. old-iron-habit
    old-iron-habit Senior Member
    Nov 23, 2012
    3,992
    Moose Lake, MN
    Its a Clark skidder chassis under the drill. Looks to be a mid 80s. If I had to guess its about a Ranger 666possibly a B series going by the picture. Normally in the USA it would have either a 4-53 Detroit or a V6 Cummins with a Clark powershift. Good machines, tough as nails, over the counter parts, not as fast moving as a like sized JD. Tires would be 5 times what the machine is worth.
    lantraxco likes this.
  7. ippielb
    Mar 31, 2014
    432
    Saskatchewan
    thank you. That’s the information I was looking for. If the thing runs and drives and the drill operates it would be a good purchase. Thinking of the things a guy could do with it. Take off the drill and sell it. Pay for the entire thing right there maybe. Then part out the skidder or sell it whole and it would all be profit. And I believe you when you say the values of the tires. I paid $650 for a single used tire for my grader.
    Now that I know a little information I’m going to pursue it a little bit maybe do some negotiating if it runs or else I’ll need help loading it.
  8. old-iron-habit
    Nov 23, 2012
    3,992
    Moose Lake, MN
    There should be a serial number stamped into the back of the drivers tub or on the frame right below it on the right side as sitting on the machine. It is on the outside of the tub. It should also be on the rear frame member on the same side. If you look front and back from the articulation joint area you should see both stamped in numbers. If they match it is probably original as built. Someone mentioned that it could be a 664. That is possible to. They are near identical with the 664 being a tad smaller and lighter machine. A few years ago I went on the Road Machinery & Supply website and was able to download and print the 600 page set of manuals for my 666 for free. I don't know if that is still possible but worth a check if you find serial numbers.
    Not sure how you took it but I meant buying tires for it would be 5 times what the machine is worth. I did not mean the tires on it had any value to speak off. They are pretty trashed.
  9. ippielb
    Mar 31, 2014
    432
    Saskatchewan
    539C-1001-CAC
    That’s the serial number stamped onto the machine.
    there is no tags or anything on the drill itself.
    oh yeah I knew what you meant, large tires are not cheap, I was just saying to buy a used tire for my grader it was $650 just for the tire and it was used.
    old-iron-habit likes this.
  10. loggers son
    loggers son Well-Known Member
    Jan 25, 2011
    105
    shovel logger operator
    bathurst australia
    Clark 668c late 70’s early 80’s. Detroit diesel 6v53 engine, 3 speed Clark power shift transmission, Clark diffs, can’t remember a ballpark weight. Given it’s got doors on the cab it was probably a grapple machine rather than a line/winch machine.
    Trev
  11. ippielb
    Mar 31, 2014
    432
    Saskatchewan
  12. Nige
    Nige Senior Member
    16,690
    The first photo on the link you posted in the OP that is taken from the front RH side of the machine shows the valve cover of, unless I am severely mistaken, a V6 Detroit Diesel, model indeterminate from the photo.
