Old Uncle Dave
I have an old IH 574. Not a back hoe but I have a question that probably applies to lots of machines.
When first started the steering and hyd lift perform as they should. After about a 15 minute warm up the steering becomes erratic and the lift only works at high engine rpm.
Yes I know it is probably worn out. The question is- is there a thicker hyd oil that will "cure" things for a while longer?
Old Uncle Dave
Old Uncle Dave
