D 40G
I tried every solenoid with no lift,or swing movement. There are 8 total. One for auxiliary pump, one for fuel on solenoid, one for starter, one for horn, one for high speed motor. I have a Duetz 2 cyl diesel so one is glow plugs. The two left must be the dump valve solenoids. The 2 close to the Racine valves are one for starter and other one for?. One of the back 4 must be a dump valve and one near the Racine valves must be the other dump valve. Think the dump valve for the lift, swing and drive is bad? Wiring is spliced everywhere on this machine. I have replaced 2 plastic connectors with amphenol quality ones. It was a rental machine before I got it but the best I could find for $8500 20 years back. It was bought with 5200 hours and now has 7560. It is a personal machine not used often now. Manual doesnt identify dump valve location. i really need to wash 34 years of dirt and grease off everything but afraid water might damage the Racine valves or something. I tried taking pictures but the relays are hard to see through all the wiring and hoses. i used to do machine tool wiring and this thing looks wired by a 5 year old. Plus no wiring schematics or part ID schematic. Has 4 relays on a circuit board and 3 transistors and about 20 diodes. Not sure of what they do either. Thanks much for your advice and help. Your instructions are excellent.
