I have limited experience in valve blocks and was wondering what the dump valve actually does? Tim_
Hi Tim,
Looks like OFF has pretty much got you taken care of, and I have only worked on 40F's with Bertea valves, he knows much more about the Racine set ups on this machine. But I can answer your question about the purpose of the dump valve. The dump valve does what the name implies, it dumps oil back to the hyd tank. JLG didn't want pressure and flow going to the valve bodies when no functions are being operated. When you have the engine running, and your not working anything, the dump valve sends the oil supply to tank. When you operate a function of that valve bank, your doing two things; 1) you power up the dump valve coil, which now diverts the oil to the valve body, and 2) you power up the coil of the valve function your operating, like telescope out. When you let go of the telescope out function, the telescope valve centers itself, and the dump valve now diverts oil to tank. Of the number of benefits of using a dump valve, one would be the scenario we just described. Let's say your telescoping out, let go of the telescope toggle, but the telescope valve malfunctions, and it continues to boom out. You could be telescoping into a wall or something and unable to stop it. The dump valve provides a redundant back up in this case. Telescope valve malfunctions, but the dump valve still operates, sends oil to tank, telescope stops. Hope that helps you out a bit.
