brianbulldozer
A couple of weeks ago my Cat 924f loader develops a hydraulic leak on the job and must have lost quite a bit of oil as the level was no longer visible in the sight glass. Fixed the problem and went to refill the hydraulic reservoir when I discovered that the oil level was not low but full above the sight glass. Asked the help if there was any way someone might have put diesel in there by mistake, but no, that could not have possibly happened. Should have drained it right then and there but instead I just drained it down to full and sent a sample in to the lab. Results came back today, and what do you know, it is almost 9% diesel fuel by volume. All my equipment is padlocked with keyed alike master locks (including this reservoir cap), so it wasn't vandalism. I was wondering if anyone has any suggestions as to how best to get all the contamination out (multiple oil changes?) and what if any damage might have been done. There is no way I would have not caught this when the last engine oil change was done about 100 hours ago. Also thinking about putting different keyed alike padlocks on the fuel fill caps of all my equipment.
