Jelte Steenkamp
Hi All.
Apologies for this long story. My first time on a telehandler and I must say I am very disappointed in the Literature available.
Looking for some specs and advice.
TH514, TBW prefix. Initially only had slow tilt function and some say boom only lifted after tilt was activated. Too many people had a go and this included adjusting relief valves and a "hydraulic flush" without cylinders cleaned and electrical checked. Then the pump was replaced as it was found preventing engine start which turned out to be a plug in dump line from main control valve.
I then inherited a machine with very hard steering and No Implements. Steering was sorted with a swapped hose on Control valve and then Pilot pressure was reduced to 30bar(435psi) as seen on schematic. Maximum pump pressure was at 280 bar(4060psi).
Implements didn't respond at all but the LS pressure reached about 7 bar when requesting boom lift. Eliminated all external valve/circuits by isolating one at a time from Main control valve. Removed control valve and found LS check valve sticky and cleaned it. No damage to any spools piston/slugs in valve. Installed and then found boom raising and Telescopic retracting but intermittently. Now I disregarded Site protocol and entered the cab myself despite not being an authorised operator and found the following codes: ACTIVE: 8519, LSI out of calibration. LOGGED: 2346, Boom angle sensor not responding, 8519, LSI load cell out of range. and a couple of others...
Worrying me is the Maximum voltage on Datalog of 19 Volts on a 12 volt system?
I have managed to lower the boom by swapping solenoid wires on the Main control valve and this confirms to me the electrical issue. Boom angle sensor intermittently reads 99 degree but resets after power down.
Questions : Is 8 volt to solenoids correct? This is not a Cat ECM but rather JLG.
Will these codes have this impact on implements? From what I could gather from the manual, an LSI problem will disable all but boom lower...
The Yellow warning "machine system distress" is permanently Active and Crab steer light flashed continuously until I disabled 4 wheel steer in the Configuration.
Looking forward to your input...
Regards
Regards
