TH460B won't go into gear
Discussion in 'Forklifts/Telehandlers' started by Pilgrimjt, Feb 14, 2015.
  1. Pilgrimjt
    Pilgrimjt Member
    Feb 13, 2015
    5
    I have a 2005 Cat TH460B that I've owned for about six years and has worked well for the most part but has had transmission related issues a fair bit. I had to replace the shift rail sensors about four years ago. For the last two and a half years it's had this problem of not going into gear at times, more so in spring and fall, but the last few weeks it's been really bad - almost daily. So far I've found nothing consistent with getting it going again except to wait. Sometime restarting a few times does it, sometimes not, other times just leaving the machine idling for a while does it. When I had the shift rail problem I was able to get the computer codes by cycling the key, but with this there are never any codes that come up. Just wondering if anyone here has had a problem like this or any experience with this?
  2. Per Eriksson
    Per Eriksson Senior Member
    Oct 24, 2007
    533
    Sweden
    How's your oil and filter, any signs of metal in the tank?
  3. Pilgrimjt
    Pilgrimjt Member
    Feb 13, 2015
    5
    I did a complete service job last fall and everything looked good. I'm fairly certain it's something electronic, I'm just not sure what.
  4. Dualie
    Dualie Senior Member
    Feb 24, 2007
    1,371
    Nor Cal
    had the same problem with a rental the ended up replacing the shift selector and doing a recalibrate.
  5. deniden
    deniden Member
    Jun 11, 2013
    8
    Russia
    There are all the instructions and spare parts catalog cat telehandler
    Who are interested in writing
  6. CM1995
    CM1995 Super Moderator
    9,341
    I would look at the shift selector also. 420D had the same problem of going into reverse only when it wanted too.
  7. Dualie
    Feb 24, 2007
    1,371
    Nor Cal
    They never did fix my biggest pet peeve about the damn thing which was you had to take your foot full off the brake before it would "catch" a gear. so it wouldnt hold well if you shifted from forward to to reverse while stopped on an incline.
  8. CM1995
    9,341
    The TH460B I had the dealer replaced the instrument cluster twice due to gauges not working, never had a problem with the trans. Got rid of it after a few years but still have ol' Blue a '90's Gradall. Still cranks, runs and lifts.;)
  9. Pilgrimjt
    Pilgrimjt Member
    Feb 13, 2015
    5
    So if it is the shift selector, would that not set a diagnostic code? So far I've never been able to retrieve any codes when it's not going into gear. It's been working good again yesterday and so far today.
  10. southernman13
    southernman13 Senior Member
    May 13, 2008
    620
    Retired
    Florida,Ga,Tn
    Where do these codes show up? I have the same machine and it's worked very well but now I'm having issues with the steering. It is stuck in what seems like two modes. Crab and 4 wheel steer. It won't domeither one correct. Theres 2 steering icons lit up on the dash as well and one of them is blinking. Any ideas?
  11. deniden
    deniden Member
    Jun 11, 2013
    8
    Russia
    There are all the telescopes full information
    Anyone interested?
  12. deniden
    deniden Member
    Jun 11, 2013
    8
    Russia
  13. Pilgrimjt
    Pilgrimjt Member
    Feb 13, 2015
    5
    southernman13, the codes will be displayed on the instrument panel in the digital windows. The way to get them to display, if there are any active codes, is to start with the ignition in the off position and cycle the key three times within ten seconds and leave it in the on position. This puts the panel in service mode.
  14. southernman13
    May 13, 2008
    620
    Retired
    Florida,Ga,Tn
    Thanks Pilgrim. Not sure what the code will be if it throws on but I'll look!
  15. ANDREW C
    ANDREW C New Member
    Feb 13, 2019
    3
    erie,co
    Did you have any luck with this problem? I have the same machine model with the exact same problem
  16. Pilgrimjt
    Pilgrimjt Member
    Feb 13, 2015
    5
    Yes we did figured it out eventually. It ended up being an electronic proportioning valve that was not working intermittently. The machine had to be calibrated after the new part was in. It's worked flawlessly since.
  17. MKMmech
    MKMmech Member
    Mar 25, 2020
    5
    Bonnyville AB
    I’m having the same issue, would you have a part number for that electronic proportioning valve or where it’s located ?
  18. Mark250
    Mark250 Senior Member
    Aug 30, 2015
    1,079
    heavy equipment technician
    victoria,Australia
    Their could be a number of reasons for your problem
    Could you tell us what the lead up to the problem is
    History, services, repairs, working conditions, intermittent fault or constant or any thing at all that may be relevant
    serial prefix SLF ?????
